overheating problems, thermostat?
Old May 3, 2004 | 02:35 PM
WaynesIroc's Avatar
Car: 1989 Camaro Iroc-Z
Engine: stock 350
Hasn't been getting real warm yet but will soon. Just on short errand runs after the car warms up it will get up to 260* real quick then cool down real quick. What is the deal? Over the winter the vaccum line going to the heater diverter valve broke so I spliced it with vaccum hose. Could the diverter valve cause this? Or could it be the thermostat?
Old May 4, 2004 | 07:59 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Could be a stuck thermostat that eventually opens now & then. I had a problem like that before. With a stuck thermostat the temp just climbs & climbs really fast.
Old May 4, 2004 | 08:27 AM
acid Burn's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Transmission: 700R4 w/ transgo kit
i had the same problem, get hot very fast, then maybe it will cool down but eventually get hot again.
it was my t-stat.
Old May 5, 2004 | 04:24 PM
Car: 89 RS
On another note, it is possible to get defective "brand new" thermostats too!! When I first tried to replace the t-stat The same problem was present. A rapid climb of the temp. On a hunch, I got another t-stat & problem was solved! The defective t-stat was a Stant one & I got it from Checkers. I have such bad luck with parts from them. It's almost like they get the bad bunch of products from companies. Got the good t-stat from NAPA. Same brand.
Old May 5, 2004 | 11:22 PM
WaynesIroc's Avatar
Engine: stock 350
Alright, thanks guys for the info. I'll try and get that thing replaced with a 170* sometime soon.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
85Special
Sep 3, 2015 04:21 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
