HELP! AC deleted now 2nd Fan won't shut off!
Old May 6, 2004 | 02:34 AM
Jeff 91Z28/L98's Avatar
What does the AC pressure switch look like? Is it the round one that plugs into the old aluminum canister? If it is, what wire needs to be grounded in order to shut the fan down?
History: Took out AC stuff, put AC delete box in, used original Heater/AC blower motor and just swapped to the smaller squirrel cage (minor dremel modification). Used original resistor from AC setup.
Now just gotta find the wires(??) to hook up to a toggle switch for manual turn on/off of 2nd fan. Please help I don't wanna drive it until I can get it fixed.
Old May 6, 2004 | 07:16 PM
Does pulling the fan fuse under the dash kill both fans or just the secondary fan?
Old May 6, 2004 | 08:25 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
just jump the two wires in the A/C pressure switch connector
Old May 7, 2004 | 12:18 AM
I would Dave but not sure where those wires are. Is the AC pressure switch shown here in these pics?
1. Blower motor
2. Power
3. Plugs into heater box
4. Plugged into Accumulator
5. Plugged into aluminum line
6. Plugged into back of compressor
7. Plugged into front of compressor
Old May 7, 2004 | 02:06 AM
After looking thru a ton of posts.... #5 in the picture is AC pressure switch and the one that needs to be jumpered......anyone??
Old May 7, 2004 | 06:30 AM
Dave Y's Avatar
Engine: 4.3L V6
either 4 or 5
try one, then the other
Old May 7, 2004 | 11:09 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
The switch should have been on the skinny aluminum tube that follows the frame rail. It should have been several inches down and directly below the word "Hotchkis" in your first pictures. #5 might have been the harness plug that connected to the switch. It is a two wire plug.
Old May 7, 2004 | 11:44 PM
Well I jumpered #5 and #4 by themselves and together no luck and I just realized that both fans are turning with the key on or running. Guess I'm going to have to do a ghetto switch from the fuse box since that's the only thing that seems to work.
Old May 8, 2004 | 05:37 PM
Well I found the reason the fans were running.....When the Procharger was installed the directions said to take the green wire and the grey wire from each respect relay and ground them. Now I just have to figure out why because the directions didn't say. Anyone have an idea?
Old May 8, 2004 | 06:40 PM
Guess I'll just use those wires to run a toggle switch to the dash.
my86bird
Oct 23, 2015 12:20 PM
middian
Sep 5, 2015 01:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
