Why Do I Have Brown Coolant????????
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ive flushed and filled numerous times already however give it just a few minutes even and my coolant turns to this dirty brownish greenish color. im not really running hot but after a nice "Spirited" drive my coolant overflow tank is bubbling and its making my damn tank look like crap with sedimant and stains!!!! any reasons why it would be this dirty over and over again?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I also have that problem with my car. In mine, the brownish color comes from rust deposits in the engine from where the previous owner had neglected the system. The bubbling in the coolant tank comes from air trapped in the system where you have been flushing and filling it.
Car: "02 z-28
Engine: LS-1
Re: Why Do I Have Brown Coolant????????
Car: 1991 Z28
Engine: 383
TRICKSTER is that goning to cause any problems for the car later on? or will it stop at the dirty coolant?
Danno well the previous owner was one to defenitly neglect this car
but i think ill need to replace the core anyway, i pulled off the panel under the passenger side dash and found a little bit off coolant puddled up. it hasent done it since but i bet it needs to be changed.
thanks for the help guys, i cant satnd this sludge in my car any longer!!!
but i think ill need to replace the core anyway, i pulled off the panel under the passenger side dash and found a little bit off coolant puddled up. it hasent done it since but i bet it needs to be changed.thanks for the help guys, i cant satnd this sludge in my car any longer!!!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, just do as Danno has suggested. When you refill the car after the final flush, I would suggest using a 50/50 mixture of anti-freeze and distilled water and not tap water.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Don't forget one bottle of Red Line Water Wetter!
If the car is used during freezing conditions, a 50/50 mix is all right, but other than that a 10-15% antifreeze solution with dist. water is better (anti-freeze cools bad, plain water(with Water Wetter) cools the best, the 10-15 % anti-freeze is for anti corrosion purposes only!)
Car: 1991 Z28
Engine: 383
good tip.....i never really drive my car in winter becuse i have another daily driver so i think ill replace my heater core, chemical flush it, and then add the right mix of coolant and such back in. if that dont work at least it isnt overheating!!!!!!!
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
By the way, I was going to suggest that you might check your fluid tank as well. The tank in my car had brown crap all over the sides and after I flushed it, I guess the new "good" fluid pulled the crap off and contaminated it.
Just a thought.
Just a thought.
Car: 1991 Z28
Engine: 383
thats what pisses me off most........after i bought the car i purchased new coolant and washer fluid tanks so they would be gleeming white but guess what?!?!? that dirty engine just stained my coolant bottle and left me some more deposits in it!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just do what I did, take one of those foam strip brushes for washing glasses and run it down inside the coolant tank and scrub it and flush it out. Worked for me.
For more info about coolant go to WWW.REDLINEOIL.COM
click on "products"
click on "coolant +other"
click on Water Wetter Tech Info"
Here's a good explanation about how coolant works, and what solutions works best under specific conditions!
click on "products"
