thermostat idea
Old May 10, 2004 | 03:16 AM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
thermostat idea
im testing an idea that poped into my head yesterday, i have a 82 ta w/a 355/th350 racing setup, now the problem is as usual running hot when running hard, i have a 165 stat and a direct drive cooling fan (non elec.) fan shroud, new water pump and freshly rebuilt motor/trans and still runs a lil warm on a 85+ degree day, gets up 220-240 dergree range, (keep in mind running above 5k rpm sometimes for that short shot hehe)
but anyway i gutted the center spring/slide assembly on the thermostat and just used the outter piece ( basically just an orfice plate) and it seems to be doing 100% better, maybe got up to 190-195 when running just as hard as when the thermostat was original. and then the temp comes back down to 175ish. so, sofar its a go and doing great, just thought id share
Old May 10, 2004 | 02:07 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah, you can buy those from Mr. Gasket and other people.. What I think you have made is simply a coolant restrictor that takes place of the thermostat..
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
85Special
Sep 3, 2015 04:21 PM
