Dual fans compared to single fan
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
I was wondering when the second fan turns on with the dual fan setup. I was told that it comes on only when the a/c is on and when the engine exceeds a certain temp. If so, what is that temp? Thanks a lot. Rick
Car: '90 Camaro RS
Is the second fan is controlled by the ECM if it is Speed Density?
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
But overrode the ECM and coolant switch using a variable speed controller made by flex-a-lite. Keeps temperature at 195. No more of that 235 degree
codeysabatini
Nov 10, 2015 04:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
