weird leaking
Old May 23, 2004 | 06:28 PM
DJXero's Avatar
Car: 1992 Camaro Z28
weird leaking
I jacked my car up to do the plugs, and as I jacked the passenger side up, coolant started leaking out of the hole on the water pump that is on the driver's side. I know if water starts leaking out of that hole then the pump is shot, but it's only doing it if the passenger side is jacked up. I'm going to replace the pump anyway(I'm sure it needs it), but has anyone heard of this before?
Old May 25, 2004 | 12:48 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
maybe the bolts are not tighten on the pump or the gasket is not sealed good. cant wait to see what happens with this.
Old May 30, 2004 | 11:23 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
thats gotta be one of the weirdest things if heard......is it loosing coolant on a regular bases or running hot at all??
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
