Engine Oil Cooler
Old May 27, 2004 | 12:33 AM
Genesis98's Avatar
Car: 88 Camaro SC
Engine: 2.8 ->305->350
Engine Oil Cooler
Is there a special Radiator required to hook this up?
Old May 27, 2004 | 01:26 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
If you are talking about the oil cooler that is stock on L98 cars, it just plumbs into the heater hose return. No special radiator is required.
Troy
So Cal
Old May 30, 2004 | 01:32 PM
Spdfrk1990's Avatar
Has anyone looked into a after market oil cooler i want to get one for my 383 b4 it goes in.Who makes the best 1?
Old May 30, 2004 | 07:58 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
It would have to be custom for the most part... You can get universal engine oil cooler kits, but plumbing the lines would be the tricky part (it can be done, but I'm just saying that there isn't a specific '82-'92 F-Body Air-Oil Cooler kit available)...
Old May 30, 2004 | 07:59 PM
Spdfrk1990's Avatar
Yeh i was just wonderin who has a good kit ive seen them in jegs.
Old Jun 5, 2004 | 01:31 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
FWIW, i am intstalling a stock C-4 corvette engine oil cooler in my T/A. I grabbed it when i got the L-98 motor out of a 86 vette. It is a closed system. The filter plate is much like th F-body one, BUT oils goes out to a finned cooler, and a 12 inch 12 volt fan combo, then back to engine. Have yet to try it, though all the parts are in my shed now. Can't wait
Old Jun 17, 2004 | 01:13 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I have a B&M cooler for oil, hooked up w/hydraulic lines.
toronto formula
Nov 10, 2015 06:17 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
