Fan Not Working
Old Jun 2, 2004 | 07:45 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Fan Not Working
I know this is a common post, but I couldn't find an answer to my problem.
Basically, my cooling fan won't come on by itself. It is a single fan set-up. I installed a manual fan switch so I can turn it on. The fan won't come on if I ground the fan switch wire or when I jump the ALDL port. It will turn on if I turn on the AC or ground the green/white wire via my switch. I'm guessing the problem is either the fan switch (it's an aftermarket Hypertech, if that matters, it's supposed to come on at 200 and off at 185) or wiring? Anyone have any suggestions or advice?
Old Jun 3, 2004 | 06:15 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I would chack the wiring that goes to the fan sensor. Hypertec is fine. I use one in both of my cars. Since the AC will kick it on, the relay should be good, so I am guessing something with the wiring from the sensor or else the engine just isn't ever getting hot enough.
Old Jun 3, 2004 | 08:05 PM
Benm109's Avatar
Engine: 305 TBI
The relay should be fine, it's a new one, I forgot to post that. Well, according to my gauge the engine gets hot enough (but this is considering this is the stock gauge I'm looking at ). I'm going to check the wiring ASAP.
Old Jun 13, 2004 | 07:27 PM
Benm109's Avatar
Engine: 305 TBI
I got the fan working by itself now. I just rewired the wiring from the relay to the fan switch, and I got a new fan switch that turns on at 227* (the Hypertech one I had broke on me ).
Old Jun 15, 2004 | 01:10 AM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Im having problems with my fan, it has a new switch. i put a new engine in the car last fall, had a hand injury and didnt hook up the sensor until recently.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
