a/c
Old Jun 3, 2004 | 05:30 PM
11sORbust's Avatar
a/c
I'm still running mafless but have switched to 6E code. Just charged my a/c with 134a. The only problem is the car builds heat with the a/c on. I have a good air dam and blocked the condenser to core support "holes"(that air gap on side of condenser).If the car is moving then it can maintain coolan temp. Just at/off idle it will build heat. I suspect that is a slightly clogged radiator(didn't check the cores). OR the ecm is adding timing for a/c. Does the ecm add spark for a/c?
Old Jun 3, 2004 | 05:32 PM
11sORbust's Avatar
this condition only happens with a/c on at idle.
Thanks for any suggestions....
Old Jun 3, 2004 | 07:04 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Should fill roughly with 75-80% r134 as the system had with r12 if doing the conversion...
Also Vader has posted the most applicable orifice tube for our cars when doing the r134 swap.. (tonna have to search i cant find it quickly). this might help u out on pressure buildup.
later
Jeremy
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
