Coolant leak (help needed)
Old Jun 13, 2004 | 07:28 AM
Katana's Avatar
Car: Firebird RS -92
Engine: 3.1L V6
Hi everyone, im in desperate need of a exploded wiew scematic of my firebird -92 3.1L V6 engine, sinse i live in Sweden its almost impossible to find one, so i hoped that some of you guys could help (please)??
The thing is that i have a strange coolant leak, it comes from below the starter engine were there is a "shield" of some kind with a small drainage hole in it, guess what comes out of the hole.
I have checked all hoses and stuff like that but everything seems ok, and still i have my own little river from my car every time ive been out for a spin.
Anyone got any ideas ?? (or scematics)
Sorry for any misspellings (Did i mention that im from Sweden )
patric_harstrom@hotmail.com
Old Jun 19, 2004 | 10:52 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
have you thought about your heater core? try taking some of your dashboard apart on the passenger side, i found anti-freeze everywhere when i took mine apart and i FINALLY knew where my coolant was leaking from.
Old Aug 20, 2007 | 12:15 AM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Re: Coolant leak (help needed)
Did you ever find out why it was leaking? I have the same problem, anyone have any other ideas?
Old Aug 20, 2007 | 11:26 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Katana, before you start removing the dash, rub your hand over the entire floor on the passengers side. If it comes up wet or damp, you need a new heater core. You may also check out your freeze plugs and you will need a good flashlight or manual to find them. If it leaks from between the engine and transmission, it could be a freeze plug on the back of the engine. Your English is as good or better than mine. Keep an eye on the coolant recovery tank, keep it at the proper level and notice how much it uses each time you drive it. Check fittings where any hoses go the firewall. Jim
Old Aug 20, 2007 | 11:33 PM
Rich92 RS's Avatar
Transmission: T56's
I'm sure he fixed his leak or at least I hope he did, since this thread is 3 years old .
I got my leak fixed (hopefully).It was from the back of the intake manifold.
Old Aug 20, 2007 | 11:35 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Thanks, I guess it`s time for bed. Goodnight.
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
