reverse flow ?
Old Jun 26, 2004 | 09:36 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
reverse flow ?
i have never ran serpintene belts ,but im under the imprestion that they are reverse flow ... is this right ? if so wouldnt the fan also turn backward ? or do all stock serpintine systems use electric fans ? (this one dont have elictric fans) its not my car its a girl freinds 89 camaro 2.8 mpfi manuel 4 speed ... not stock , but im not sure what mods it my have , only thing for sure is the over heating , has air dam ,new water pump,new rad ,new thermo, freash antifreeze , .... got to do more then throw parts at it ... lol ...thanks for any help .... tao
Old Jun 26, 2004 | 10:12 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
No SBC serpentine belt pumps are NOT reverse flow, they are reverse rotation.
The LT1 engine is a true reverse flow.
Old Jun 26, 2004 | 04:46 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
reverse rotation ...reverse flow
ummmm ok ..... then the fan is or isnt the same on the two systems ?????
Old Jun 26, 2004 | 05:45 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Anything f-body with a serpentine belt will have an electric fan, which is independant of the water pump... You can get reverse rotation mechanical fan clutches/blades (and flex fans) if you want to run a mechanical fan... Yes, a standard fan will turn the wrong way.
Old Jun 26, 2004 | 05:53 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
thanks
ok .... thanks that awnsers my question .... funny cause i got two cars confused its a 1989 with a 350 not a v6 it was early i wasnt quite awake ... thanks agian ... tao
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
84redta
Sep 19, 2015 09:58 AM
