R134a How Many Cans???
Old Jun 27, 2004 | 08:12 PM
knight75's Avatar
Car: 1987 Pontiac T/A with Knight Rider conversion
Engine: 2.8 V6
Transmission: 700r4?
Hey guys I just retrofitted my firebird ac and I put (2) 12oz. cans of 134a. One of the cans had leak sealer and system cleaner in it and the other was just plain old 134a. Should I put anymore cans into it. I have an ac pressure gauge but it still reads low.
AC seems to be cooling and feels good right now!
Should I add another can???
Thanks guys!
Knight75
Old Jun 28, 2004 | 09:16 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Re: R134a How Many Cans???
Knight75
Number 1 rule of AC work...If it ain't broke, don't fix it...
that said, these retrofits are more of an art than an exact science. Ideally, these cars can use about 2 1/2 cans. 3 whole cans would have you slightly overcharged, and will deminish your cooling capacity.
2 cans is slightly undercharged, but many r134 conversions cool better with a slight undercharge.
The most common problem with an undercharged system is compressor overheating. Your compressor is cooled by the returning refrigerant line. With the engine idling, ac on max, and blower on high, feel the suction line (the one coming from the accumulator to the compressor) at the compressor. It should be good and cold. As long as it feels good and cold, your system has sufficient charge to keep the compressor properly cooled. Beyond that, charge weight is determined by system performance.
Since you have already stated that your cooling performance is satisfactory, if your return line is cold, I would leave everything alone, and call it good enough.
Frozer!!!
Jan 19, 2024 04:55 PM
pimp2303
Jul 27, 2017 02:03 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
