4th Generation Dual Electric Fans
Old Jul 2, 2004 | 05:50 PM
virole's Avatar
Car: 1986 Firebird Trans Am
Engine: Lg4
Transmission: 5 speed
I found this on ebay. They come from a LS1 engine.
Will they work on a third gen Trans am?
How hard will be to install it?
http://cgi.ebay.com/ebaymotors/ws/eB...908474444&rd=1
Old Jul 5, 2004 | 11:03 AM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Good idea
This may be a less expensive route than buying aftermarket. I'll be watching the tread closely.
Old Jul 6, 2004 | 09:55 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I've got 4th gen fans in my '84, out of an LT-1 powered car. I imagine the LS-1 fans could be adapted also, although the shroud is slightly different. I had to finesse the shroud quite a bit to get them to sit in the way I wanted them, but I'm very happy with them now. If you get a set of fans make sure and get the electrical pigtails with them too so you have the weatherpack connectors to plug into the fans. That makes the wiring much easier. Here's a link to a thread I posted about installing my setup: https://www.thirdgen.org/techbb2/sho...hreadid=186270 Good luck!!
-Paul
Old Jul 6, 2004 | 03:59 PM
virole's Avatar
Engine: Lg4
Thanks for the info and the link!
You think a mechanic challenged person can work this out?
Have any advice on how to do this swap?
Hotrodboba400
Dec 10, 2019 07:07 PM
scotrans am
Sep 5, 2015 04:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
