stock oil cooler
Old Jul 11, 2004 | 08:20 AM
snapping turtle's Avatar
stock oil cooler
Can this be removed with out any parts needed to have the oil filter be able to screw back on . I don't whant to run into any problems when I take it off . The reason is because I 'm getting a new raditor and it dose'nt have the oil cooler taps on it .
Old Jul 11, 2004 | 08:33 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the stock oil cooler had coolant running through the adapter
Old Jul 11, 2004 | 02:25 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Transmission: 700R-4
So that's coolant running through the hoses at the filter housing? I was about to change those out as a precaution, but if they are just coolant hoses, I'll wait.
Old Jul 14, 2004 | 07:44 PM
BOTTLEDZ28's Avatar
Transmission: A4
you should be able to just remove the filter then remove the cooler adapter. the filter shoudl then just go back on. Like I said I think, If now the there has to be a fitting that gets installed into the block so that you can screw the filter back on.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Exxon Limited
Aug 9, 2015 08:13 PM
