New a/c compressor....oil goes where?
Old Jul 18, 2004 | 04:08 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Silly question, but just to make sure I do this right. Got the correct oil for GM applications. Don't know where to actually put oil in the compressor though.
Is it where the sensor on the back goes?
Also...what is the consensus on how much? Some say (if it is preoiled) to dain out the oil and fill in the same amount with new oil.
If its not pre-oiled....then how much?
Old Jul 18, 2004 | 08:02 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Put two ounces in the compressor, turn the front inner drum to actually rotate the pump a few turns. Put the oil in either hole where the hoses bolt up. Put the rest of the oil in the new drier/receiver.
Old Jul 19, 2004 | 02:42 PM
Thanks....just to be sure...when you say either of the two hoses, you mean where the high and low side lines bolt?
Old Jul 19, 2004 | 03:42 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Yes. look into the holes and you can see into the compressor case.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
