what wire?
Old Aug 1, 2004 | 03:18 PM
Kandied91z's Avatar
what wire?
is there a wire in the fan harness that you could "jump" to essentially turn on the fans without needing the thermostat and cpu to do it?
Old Aug 1, 2004 | 05:37 PM
MdFormula350's Avatar
just ground the F terminal wires and put them to ground.
those are the grounding wires to the relay and just splice into them and hook the other end of the wires to a body ground.
Old Aug 2, 2004 | 01:59 AM
Kandied91z's Avatar
thank you for the diagram...
Old Aug 7, 2004 | 07:04 AM
57plymouth's Avatar
Will that leave the fans on when the ignition is on or do you have to install a switch to manually control the fans?
Old Aug 8, 2004 | 04:02 PM
if u dont use a switch it will make the fan(s) come on when the relay gets power via turning on of the ignition(car on).
u adds switched to control the off and on of the fans when the car is on.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
