what is this part?
Old Aug 8, 2004 | 12:09 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
Transmission: 700-R4
what is this part?
located on the thermostat housing (passenger side of car)
Old Aug 8, 2004 | 12:34 PM
Parrydise7's Avatar
I think it is called a diverter. A rubber hose slips over that extension, right? I've got one on my 1985 Camaro.
Are you replacing it? If you have a knowledgeable parts counter guy he should be able to confirm that it is a diverter if you take the photo with you.
Quick edit: if you go to a parts counter (and my recollection is that these are awfully expensive) refer to it as a diverter valve. Trickster may be correct, but I really have no idea.
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Off hand it looks like the coolant temp sensor.
Old Aug 8, 2004 | 02:28 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
oh i forgot i broke off the second "prong" just to the left of the first one
Old Aug 10, 2004 | 04:05 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Trickster, I have to disagree here, although you DID say "off hand."
That's the EFE thermal (or temperature) vacuum switch. When the engine temperature is below normal operation levels, it switches "on" and routes vacuum to the air manegment valve, more commonly known as the "heat riser valve." That valve is located on the right side manifold. That valve closes when vacuum is applied. So, when the engine is warming up, that valve will be closed. That routes the right side exhaust gasses up through the intake and out the left side manifold. This warms up the intake quicker which increases fuel vaporization and decreases emissions. This is all part of the "Early Fuel Evaporation" system or "EFE" setup.
If you are needing to replace it, these will work (not that expensive, either)
http://www.partsamerica.com/SelectPa...acuum%20Switch
i would use AC Delco 212-72. And, obviously, take yours and compare.
Old Aug 10, 2004 | 03:17 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
hmm thanks!
i was looking through jegs' online repair manual and found it about the same time you posted
if it's broken, that just means that the manifold would take longer to warm up, correct? can i drive safely with it plugged in, but no vacuum hoses hooked up?
Old Aug 10, 2004 | 11:19 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yep. Which means it takes longer for the temperatures to reach the point where fuel vaporizes for better emissions and what not. I would plug the ports on the heat riser valve and the vacuum source at least.
You can drive safely without it, yes. Since a vacuum signal closes it, the default position is open.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
