Water Pump Long Or Short
Old Aug 11, 2004 | 07:54 PM
STEVE OC's Avatar
Hey Guys
I have a 1986 Camaro IROCZ with a stock 305 TPI engine , I need to replace the water pump pully , can someone tell me if this engine was fitted with a long or short water pump so that I can order the correct pully to suit
Thanks Steve
Old Aug 12, 2004 | 01:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Every small block car made since 1969 (except Corvettes) has a long water pump. If you have V belts you need a standard rotation long pump, if you have serpentine you need a reverse rotation long pump.
Old Aug 12, 2004 | 02:33 AM
STEVE OC's Avatar
Thanks for that info
Steve
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
