Think this will solve my cooling issues?
Old Aug 12, 2004 | 11:27 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I was having overheating problems with the stock dual fans mounted about 1.5" away from my Ron Davis 31x19 Dual 1" core radiator, so I had a full shroud made and I'd like to mount the stock fans in/on it (rather than spend 200+ for aftermarket fans....). My cooling problems were at idle/low speed only, which leads me to believe that the way I had the fans mounted caused them to not pull enough air through the radiator.
I've done a search, but only found what people *think* the stock dual fan setup is rated at (CFM), do any of you guys know what it really is?
Old Sep 3, 2004 | 04:58 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Scott, my stock fans are about 1\4 inch behind the rad. That might be your problem.
Old Sep 3, 2004 | 08:28 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Yeah 1.5 inchs is way to far away to not use a shroud. I have a feeling that the shroud will solve your problems.
Old Sep 7, 2004 | 08:37 AM
Scott_92RS's Avatar
Car: 1992 RS
Well, I had to scrap my custom fan shroud because I ran out of time to get the fans mounted properly. I modified an LS1 shroud and use that, seems to be working great, although I havent thouroughly tested it yet.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
