How long's too long
Old Aug 29, 2004 | 01:04 AM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
How long's too long
just wanted to know how long it is safe u have a dry coolant system, like can the inside rust and cause problems? or doesn't it matter if the block, rad, water pump...r all empty and dry
Old Sep 2, 2004 | 11:53 PM
chio987's Avatar
Engine: 305 4bbl HO
T.T.T.
may seem stupid but i just don't know if it's ok to leave the block empty. i don't think it would matter but i'm having a brain fart on this one
Old Sep 3, 2004 | 10:51 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Youll get a small amount of surface rust but its no big deal. Just do a flush with a garden hose to get rid of any loose rust flakes.
Old Sep 3, 2004 | 01:01 PM
bobsroc's Avatar
Car: 1987 IROCZ
Empty
Might I ask why the coolant system is empty? If your concerned, I think you should refill it with 50/50 to keep insides for rushing. That for sure is the safest practice.
Old Sep 3, 2004 | 08:34 PM
dankhound's Avatar
Car: 91 RS
The difference between the rust in an empty vs. filled engine isnt all that great. Its always a good practice to do a quick flush on a system every year because rust forms no matter what you do to prevent it.
Old Sep 3, 2004 | 08:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Given a choice between leaving a car parked for an extended period with the coolant full or draining it, I'll drain it every time.
Old Sep 3, 2004 | 11:11 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
z 28 jari
Sep 14, 2021 10:03 PM
Formula8r89
Sep 22, 2015 04:24 PM
corey8084
Sep 17, 2015 02:56 PM
Street Lethal
Sep 7, 2015 01:09 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
