need a diagram
Old Sep 10, 2004 | 10:47 PM
digital_burnout's Avatar
Car: 91 camaro z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 410
need a diagram
ok now the fan doesnt turn on when the ac is on and i need a diagram for a single fan showing all the relays and stuff so that i may check and see if i can find the problem. thanx.
Old Sep 10, 2004 | 11:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here you go!!!!!!!! BTW, the coolant fan relay is mounted on a bracket on the driver side firewall on the right side of the fuel pump relay as you look at it.
Old Sep 12, 2004 | 02:20 AM
Car: 91 camaro z28
Engine: 355
Axle/Gears: 410
thanx for the help
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
timonator
Sep 11, 2015 05:11 PM
