Is it okay to put a mechanical temp gauge sender into the water pump plugged hole??!!
Old Oct 10, 2004 | 01:52 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I've got an Edelbrock water pump that has a plug on the top. I guess it is supposed to be for a heater hose, which I don't have(not using a heater I live in FL). I also have 2 ports on my Edelbrock heads, but I am saving those for left and right cylinder head temp gauges. It is safe to put the sender in that water pump port or will the impeller shred the sender? Will the water pump cause any fluxuations in the readout of the gauge due to the coolant flowing rapidly out of the pump? I'm using an RPM air gap manifold so I don't have any sender locations there either, just one behind the carb which I am going to use for intake air temp(I'm a gauge ***** can you tell?) Any ideas are appreciated. Thanks, Paul Moore
Old Oct 13, 2004 | 04:31 PM
firebirrrrd's Avatar
Im not sure if the impeller would touch the sender but I do know they sell water necks with a hole in them for temp senders.
Old Oct 13, 2004 | 04:51 PM
paulmoore's Avatar
Normally, I would put it in the water neck, but I have one of those 360 degree swivel filler necks from CSR and it only has a 1/8 NPT fitting for a coolant overflow catch can.
Jeremys87
Jul 14, 2022 09:08 PM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
