Easiest way to drain coolant for heater core install???
Old Oct 27, 2004 | 06:14 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Hey guys, I just got around to installing my heater core (man what a biotch that was) and now I need to put it all back together and hook up the hoses. Question is, what is the easiest way to drain coolant for this process? I am replacing all the heater hoses and I don't want a giant mess of coolant again. I say again because when I put my performer intake manifold on I had to disconnect the bottom radiator hose to drain and coolant got everywhere. So help me out fellas!
Old Oct 27, 2004 | 06:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Drain plug on the rad.
Old Oct 27, 2004 | 11:45 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Yeah, but it is very hard to get to, at least it seems to be, we are talking about one on the bottom of the radiator?
Old Oct 28, 2004 | 01:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
At the bottom of one of the side tanks.
Old Oct 29, 2004 | 11:29 PM
RICHRAD's Avatar
About that drain ****..should my radiator support have a hole there for me to get a hose on that drain?...It appears that I need a 90* elbow of some sort to direct that coolant away from the radiator support...Any tips for not making a mess?
Old Oct 30, 2004 | 02:04 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yep. Lay down some towels. Put a big pan under there. Twist the stopper and stand back. It's not as bad as it sounds. You can control the flow of coolant by opening/closing the drain plug.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
