Where exactly is the fan relay?
Old Oct 29, 2004 | 08:23 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: built 700r4
Well my fan is not turning on and I was told to check the relay, but I don't know where it is.
can some one tell me?
Old Oct 31, 2004 | 09:00 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My 88 has dual fans and both relays are right beside the battery.
Old Nov 1, 2004 | 07:10 PM
meangreen92's Avatar
Car: 91 Formula
the relay should be on the drivers side under the hood, in the corner between the brake booster and the inner fender.... there should be two square gray boxes plugged into a bunch of wires. one is for the fan to turn on, and one turns the secondary fan on(if you have dual fans).... it shouldnt be too expensive and should be available in any parts store....
Old Nov 3, 2004 | 03:52 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
All 3 relays there (2 for the fans and the other for the fuel pump) are the same one...there 17 bucks and available only at a GM dealer
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
