Name This Part
Old Nov 9, 2004 | 04:31 PM
MasterEvilAce's Avatar
Name This Part
I guess this part was leaking somewhere like CRAZY, today.. I had no coolant in the radiator what so ever.. but there appeared to still be some in the block. I had to drive home, and the temp gauge was normal... and there was still coolant in the block, which I don't understand how... well I went to move this part, and the thing snapped one of the lines off..
does this thing have a name, and will it be cheap to replace?
Also, what's the chance of the engine seizing? The battery was basically completely dead when I went to restart it.. I took some hoses off, and forced cool water into them, and the orange dexcool approved coolant came out.. So that's how i know there was coolant still in the block.. I did that until the water was slightly warmer than the water going in.
Does the engine have to be pouring out steam before it seizes up, or what? Again, temp gauge was practically in the center constantly, sometimes going higher, but dropping back down. I think this is around 220? And is where it is normally at.
Old Nov 9, 2004 | 04:32 PM
damnit.. *smack*
forgot the picture
Old Nov 9, 2004 | 05:36 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
This is the heater core valve, it practically opens or closes the hot water flow to the heater core based on your A/C control settings (warm/cold etc). It is vacuum operated from the A/C control unit.
Not sure of the completely official name.
Hope this helps.
Lou
Old Nov 9, 2004 | 10:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is called the heater flow valve or heater diverter valve depending on where you go to get a new one. The manual calls it the diverter valve while parts stores call it the flow valve.
Old Nov 14, 2004 | 04:19 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I got mine at Autozone & Im sure you will find it at most autostores.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
