Good quality coolant fitting plugs?
Old Dec 4, 2004 | 02:52 PM
Damon's Avatar
I have eliminated the heater core bypass system on my 92 RS. This leaves a fitting on the metal heater core return line that runs up the pass. side frame rail that needs to be plugged (3/4"). The cheap fitting caps that you buy in the "Help" bubble packs at the parts store are very low quality. They crack, split, disintegrate and start leaking after only a few months (the fact that the exh header tube runs about 3" from it probably doesn't help).
Does anyone make a coolant line fitting cap in 3/4" size with some quality to it?
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
fonzie85
Aug 13, 2015 11:50 AM
the_nikfive
Aug 11, 2015 02:46 AM
