question about heater core and coolant level
Old Dec 5, 2004 | 08:30 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well, maybe a common sense ?, but i'm gonna ask anyways. today i finally got to turn the key on my new engine, got it running, and for the most part, was ok. i put water (for now) in the block, about a gallon, put the t-stat in, and about another 2 1/2 gallons in the radiator. all seemed to be ok... then at one point in another turn, i turned on the heater and later checked my water and it took another 1/2 gallon, so my question is, did it take that 1/2 gallon to fill the heater core and lines? it doesn't appear the water went anywhere else undesireable, but just wondered if that happened cuz the heater control valve was closed before and then opened...
another question i had was, is it common or normal for water to seep at the head bolts at first til the engine gets hot with the new head gaskets and thred sealer? at first i saw a couple of minor seeps from outer head bolts, but then never saw anymore at all when i ran it a couple of other times. initially i wouldn't think it's normal at all, but someone told me i might see that until the gaskets heat up and really seal up.
KAM
Old Dec 5, 2004 | 08:42 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
i dont know about the moisture by the head bolts.
but about the heater core, there is quite a bit of line between the block and the core, and the core itself is not that small, so yeah seems like 1/2 gal is about right for filling the core and the lines to/from it
Old Dec 6, 2004 | 06:31 AM
Car: '91 Z28
Axle/Gears: 323's
and after thinking about it, i didn't watch the coolant level when i started it up, so it probably sucked some down on the start and then once the thermostat opened up, combined with the heater, probably pretty much accounts for it all.
KAM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
