Stock Temp guage dead
Old Dec 13, 2004 | 09:55 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Just noticed it....its stuck on zero and wont move..
What are the 1st things to check?
Old Dec 13, 2004 | 10:04 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
When you turn the car on, does the gauge peg itself as a "self check" then drop to 0? Or is it just stuck at 0 all the time?
Old Dec 13, 2004 | 10:10 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Check the connection to the sensor on the driver's side head. If the wire is not making contact the guage will peg at zero.
Old Dec 13, 2004 | 10:38 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
its stuck on zero and never checks..never moves.
When i replaced the plug wires on the drivers side i must have accidently pulle the wire...not sure what its suppose to look like or connect to...
Old Dec 13, 2004 | 10:48 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
There's a single green wire that would be floating over there somewhere. It connects to a little sensor screwed into the driver side cylinder head. It has a single male blade-type connection, so the green wire will have a single female reciever.
Sensor looks like this:
Old Dec 13, 2004 | 01:05 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Thanks...you guys ROCK ! :rockon:
italiano67
Dec 11, 2016 09:21 AM
Genopsyde
Oct 7, 2015 08:35 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Irocohio
Aug 12, 2015 08:03 AM
