Leaky rad Hose question
Old Jan 17, 2005 | 06:54 PM
slo406's Avatar
Car: 02 Echo/91 trans am
Engine: 1.5/6.7
Transmission: a4
Okay so i just bought a complete set of goodyear radiator hoses (the blue set) and i got done hooking everything up and the return hose that connected from the filler cap to the mani is leaking at the filler cap/housing ..i tightened the hose clamp as much as posible and the filler housing isnt cracked or anything..any ideas?
Old Jan 18, 2005 | 07:50 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If you have the stock rad with the plastic side tanks you may have a crack that is not visible. A common problem is when you remove the old hoses if you worked them off instead of cutting them off, you place stress on the plastic and you get a crack that may not show up until it is under pressure. You may have to pull off the hose and get a light and a magnifier and inspect the area around the hose fitting. Also look directly under the hose fitting on the rad, thats a common place for it to crack. It is unusual to have to tighten the clamp excessively to form a good seal.
1992 Trans Am
May 10, 2023 07:19 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Catcher55
Aug 15, 2015 07:08 PM
