how do i remove this silver canister????
Old Jan 23, 2005 | 11:10 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
how do i get this out? anything technical i need to know or just unbolt everything and yank it? thanks:hail:
Old Jan 23, 2005 | 11:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just remove the line fittings and maybe one bracket and lift it out. Don't forget to remove the old orifice from the rear fitting.
Old Jan 23, 2005 | 11:41 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
huh? where and what is an old orfice ring??? thanks
Old Jan 23, 2005 | 11:53 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not an orifice ring, just a plain orifice tube or as it is sometimes called, an expansion tube.. It acts as a filter to keep trash and other garbage out of the system. Here is a picture of it.
Old Jan 23, 2005 | 11:58 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i assume its the one leg going into the black box/covering?? thanks trick
Old Jan 23, 2005 | 12:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
and you assume correctly. BTW, I haven't forgotten the other info on the cruise control. Just busy.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
