no fan
Old Feb 21, 2005 | 06:14 PM
4monkeys's Avatar
Car: 89 rs
Engine: 305 tbi
Transmission: 5 spd.
no fan
my fan will not come on. it comes on when the ac is on but not at 220 degrees. I have replaced the relay. any ideas?
Old Feb 21, 2005 | 07:06 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Have you checked to see if there is a temp switch?
Old Feb 23, 2005 | 11:33 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Yeah... maybe it's this component you need to replace:
Low Temp Fan Switch
Old Feb 24, 2005 | 03:36 PM
4monkeys's Avatar
Car: 89 rs
Engine: 305 tbi
The temp. guage works, and I'm trying to locate the coolant sensor at an auto parts store. It does nothing even when I jump the wires,even at the E.C.M
Old Feb 24, 2005 | 03:44 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Cooling fan switch is in pass side cylinder head. Looks like the one in link above. With key on ground wire to switch, fan should come on. Stock switch doesn't come on until around 235 or something. Get an aftermarket lower temp switch to solve problem.
Old Feb 24, 2005 | 04:35 PM
Cadillac's Avatar
Werd.
Old Feb 26, 2005 | 04:54 PM
Vader's Avatar
Another thing to consider is that if you are using the dash-mounted temperature guage to diagnose this "problem", your actual temperature could be considerably different that what that guage is displaying. You might not be anywhere near 220°F coolant temperature.
Old Feb 27, 2005 | 11:54 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
fan temp "on" is 226*
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
