Griffin Or Not?
Old Mar 10, 2005 | 03:39 PM
cndyapple88's Avatar
Car: 88 camaro
Engine: 305 tbi
Griffin Or Not?
hey what do you guys think of the griffin brand of radiators i just spent 450 on one and hope it holds up to the hot cali summers
Old Mar 10, 2005 | 03:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
see if you can cancel your order....
get a "generic" GM one instead of the "custom fit" one..... they both fit the same and have the same radiator outlet locations...
the only diff is one heater hose bung, and $250.
either run a "old style" heater setup, spending $12 or so for a screw in bung... or spend ~$15 - $25 and have someone TIG a nipple onto the radiator when you get it.....
but yea, both keep the car cool.. even if you have a 550+hp demon.
Old Mar 10, 2005 | 09:39 PM
Car: 88 camaro
Engine: 305 tbi
generic?
yea my friend has a generic one that doesnt even keep his 350 cool too late its already installed and the temp gauge wont leave 150
Old Mar 10, 2005 | 09:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
"doesnt keep his 350 cool" and "wont leave 150" makes absolutly no sense. 150 is too cold.
Old Mar 10, 2005 | 10:52 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
its my car that hes talking about. the standard GM radiator is not enough to keep a 350 cool. its always sitting up over 220 no matter what im doing, unless im on the freeway. his car whether we are cruising in a parking lot or driving at normal speeds will not get any hotter than 180, which is pretty nice.
im looking into buying the same radiator but i will be buying dual electric fans
Old Mar 11, 2005 | 02:13 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I think what he means is buy the generic GM radiator from griffin as opposed to the Camaro specific one and you will save a couple hundred bucks...
Have fun
Old Mar 11, 2005 | 03:16 AM
Night rider327's Avatar
Car: 1988 Camaro
I'm pretty sure MrDude_1 is talking about a uni. fit for GM cars aftermarket alum rad. Not a stock GM rad.
In saying GM he means outlet on bottom pass side, inlet on top driver's side.
I'm glad somebody has money to throw around, cause a darn sure dont.
I got the summit 31" x 19" alum uni fit for GM cars rad for $180. No heater hose barb or trans cooler. $50 trans cooler, and $4 plumper pipe strap, $2 hardware store bolts, and I was good to go, and only spending $234.
Plumb heater like it should be.. One hose to water pump, other hose to intake.
Old Mar 11, 2005 | 10:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
exactly.
Old Mar 18, 2005 | 08:57 PM
JOHNNY383's Avatar
Car: 87 T/A
Engine: 383 TPI
Griffin --- YES...
J383...
Old Jan 15, 2009 | 05:12 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Re: Griffin Or Not?
Since I might be probably unclear asking in another topic, maybe here some one will help me..
I am lookingfor that "screw in bung" ..
Can you tell me what should I buy..?
Or maybe even link to it at for example summit..?
thank you,
Old Jan 15, 2009 | 07:16 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: Griffin Or Not?
Holy back from the dead batman!
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Jim85IROC
Dec 6, 2002 12:09 PM
92 zzz28
Oct 15, 2002 10:40 AM
LILRED383
Apr 26, 2001 07:49 AM
