cooling fan stuck on
Old Mar 12, 2005 | 08:52 PM
lawrence_1md's Avatar
Car: 86 MonteSS/ 92 Camaro RS
Engine: 350 TPI / 305 TBI
Transmission: 200R4/ 4L60
Hey just thought I would see if some one could tell me why my cooling fan would stay on when the engine is running? My wiring harness is from a 86 camaro with the 305...
The relay is new. For some reason the PCM is commanding it on. From the wiring diagram I have, the only input is the ECT sensor and the A/C switch. There are no codes set and the coolant temp is reading correctly.
Thanks for the help!
Matthew
Old Mar 14, 2005 | 10:41 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
only reasons I can remember for the fan being on is the ECM seeing a problem (code, my code 33 IIRC turned the fan on all the time) or perhaps the AC switch.
Can't recall the specifics on the AC switch, but if you don't have it wired up or jumpered, the fan is either on all the time, or won't come on at all. I *believe* it will run all the time if the fan switch connector isn't jumpered.
Old Mar 14, 2005 | 05:02 PM
what did you do to get your code 33 to go away?
Old Mar 14, 2005 | 05:13 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I used my factory service manual and followed the troubleshooting flow chart for the code 33, which told me the MAF was bad.
Found a known good MAF for cheap (the wells one everyone recommended I couldn't find ANYWHERE, and I looked hard) and it certainly did cure the problem.
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
