Cooling Fans NOT comming on
Old Mar 14, 2005 | 08:42 PM
EmoDork138's Avatar
Car: 88 Trans Am GTA
Engine: 5.0 TPI
I have a '88 Trans Am GTA w/ dual cooling fans. Before I put her away for the winter (only a few weeks left - joy) the car got hot because the fans did not engage. I ran a wire from my battery and jumped the fans and they spun just fine - not a mechanical failure. I checked my fuses from the box, and they also look fine. I'm aware there may be a fan relay under the hood, the question i ask is where is this relay, and/or what could be some other reasons for the fans not to engage? Does anyone have any pictures of the fan relays? Can I pick them up at Autozone, or shall it be a trip to the boneyard. Thanks guys.
Old Mar 18, 2005 | 02:18 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
I know on '91 & '92 TPI's the relays are behind the brake booster, maybe the '90 model to (never owned a '90). As for the '88 model, I'm not sure. I've seen diagrams with relays close to the battery and next to the Radiator. You might check around them area's.
Old Apr 11, 2005 | 09:05 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
take the fan switch wire out of the connector on the head(pass side rear) and ground it. if the fans come on, the switch is bad.
Old Apr 26, 2005 | 04:32 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
make sure ignition is on, engine off...
Another way to make the fan come on is to turn on the a/c (make sure heat selection is set to cold) lol
new fan switch options
Old Apr 26, 2005 | 03:18 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
yes, you would have to have power to the fans.. so ignition would have to be in the "ON" position.
Old Apr 26, 2005 | 07:20 PM
EmoDork138's Avatar
Engine: 5.0 TPI
Thanks for the ideas... ended up replacing the relays... the local store even had 2 in stock (to my amazment) anyways.. they fired right up. Just like the champs i hoped they'd be!
thanks again!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
