How many rows?
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
How many rows?
I'm searching for a new radiator and I've found a store that has a "upgrade 3-row" radiator. What comes stock?
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
1 row aluminium
Make sure its not the Brass/Copper one. Summit/Jegs have dual 1" row aluminium for under $200
The three row is from 1A Auto. Why not the brass type, and do these three row radiators fit?
Car: 92,94 Camaro, 95 Bird, 12 Silverado
Engine: 5.7, 3.4, 5.3
Transmission: 700R4, T5, 6L80E
Axle/Gears: 3.70, 3.42
Keep in mind that you can't mount anything to an aluminum radiator (ie. using the zip strips that go through the radiator to hook up an aftermarket fan). Its too brittle of a metal and will crack the core.
When looking at radiators there have been two types advertised. One is a "three core" and the other a "three row." what is the difference?
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ive done this numerous times over the years, and so has 84747638463 other people.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
same thing.
i can attest that the rows really dont matter. you need to check the surface area.
given the radiator is the same size and material, a 1 row 1 5/8 tube radiator will outflow a 3 row 1/2 tube
i have a pretty radial stroker and my car has never seen over 190 sitting in traffic in the dead of summer. runs 170 all day long.
all i have is a ole cheapy stock replacement for a v6 from advance.
Denricci22
Sep 18, 2015 09:02 AM
