Jet Switch or Factory Replacement?
Old Mar 19, 2005 | 01:00 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I am going to replace my fan switch because I believe it has gone bad. Should I replace it with an OEM or JET switch?? If I used the Jet switch will my SES light come on??? I have the stock ECM and Chip.
Old Mar 21, 2005 | 12:19 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
Your talking about the Passenger side Fan Switch?
If so, the jet sensor will not make your SES light come on, this sensor is not connected to your ECM. Only the Driver side sensor is. This, however is the way my TPI is wired.
I have the 195 jet switch on my car and have had no problems.
Old Mar 22, 2005 | 06:53 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Save yourself some money. If you are considering replacement of your OEM fan switch and want one that activates at 200deg find it cheaper at: http://www.madvet.com in the cooling section.
Old Mar 22, 2005 | 07:01 AM
Wadebryant's Avatar
Should have included this in the last post;
Go to: http://www.madvet.com
The fan switch you may be interested in is in the C-4 section.
Part# is 609-106 for 1984 to 1991 cars
$12.99 (nice)
Old Mar 22, 2005 | 07:50 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Jet Switch or Factory Replacement?
To test this, remove connector from switch and put ignition key in the "on" position. Ground connector and fan should come on. Definitely get a low temp switch if it is bad.
Old Mar 22, 2005 | 01:13 PM
Stevo's Avatar
Car: Pair of 92 Z28s
$12.99 (nice)
will this work on my 92...? sence i know that is for a corvette sight i dunno?
Old Mar 22, 2005 | 01:25 PM
91Z28-350's Avatar
Should work. The Jet fan switch has a different plug for it, so you need to cut and splice a new pigtail on it. You can't exactly go back to stock without putting the stock pigtail on it.
Old Mar 22, 2005 | 01:58 PM
Wadebryant's Avatar
Sure, as long as you have a 305/350 with the fan switch on the passenger side head.
Old Apr 17, 2005 | 08:52 PM
Stevo's Avatar
sorry to bring this post up again but do i want to buy the harness with this or just cut and splice the wires myself?
Old Apr 18, 2005 | 06:57 AM
Wadebryant's Avatar
I ordered the switch and pigtail. However, my stock pigtail connector plugged right up to the new switch and works just fine.
If your connector is broken or hardened by heat etc., get a new pigtail also. Easy to install, one splice, cheap insurance.
The Hypertech and Jet fan switch kits come with the pigtail but, you can order just the fan switch or both from madvet.com also. Madvet link and part #'s are posted in previous posts.
Old Apr 20, 2005 | 02:42 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
Transmission: Built 700R-4
hey so would this work on my 91 rs?? cause i only have one fan and the vettes had two..... and is this the sensor in the engine or in the intake manifold?? thanks again guys!
Old Apr 20, 2005 | 03:06 PM
Wadebryant's Avatar
Yes, the fan switch will work with your 91rs 305, single fan, just fine. I have this same setup in my 91rs 305. The switch is located between #6 and 8 cylinder plugs, passenger side head. There is a single wire lead to it.
Just put in a cooler themostat, replace the OEM fan switch with one of your choice. Run cooler.
Old Apr 20, 2005 | 03:34 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
thanks alot sound like a plan i needed to replace that anyway cause its melted off lol!
Old Apr 21, 2005 | 07:14 AM
Wadebryant's Avatar
Pretty common for the female end of the pigtail to be melted or cracked from heat and age. Both of my 3rd gens needed new fan switch pigtail connectors too.
Old Apr 21, 2005 | 09:40 AM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
lol yeah, hey one more Q, do i have to buy there sensor too? or just the harness, i already bought a new sensor i just needed the pigtail but i still want the lower temp so do i have to buy the sensor from them, cause i just bought the oem type from napa
Old Apr 21, 2005 | 01:05 PM
Wadebryant's Avatar
You really shouldnt need a harness unless you plan to activate the fans from inside the car. Thats up to you.
From reading your posts, it appears that what your saying is that you need a new pigtail connector and a cooler activated fan switch. http://www.Summitracing.com sells the Jet switch and pigtail kit, #JET-60600 and the HYPERTECH switch and pigtail kit, #HYP-4026 (176 deg on) and #HYP-4028 (180 deg on) kits. I also listed the Madvet info in a previous post for cost compairison, alternatives. Any of these kits will help your car run cooler. Not sure about the NAPA switch, you might inquire.
Hope that helps.
send me a PM if I can be of any more assistance.
Old Apr 21, 2005 | 02:15 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
thanks i found a new pigtail today so i guess i dont need to buy that anymore so ill just go and put the new switch in cause the one from napa dosent turn on till 238 according to the service manual that i was reading. so thanks for the help and hopefully this will sovle my problems with it getting too hot i already put in a 180 thermostat so i should be set. thanks
Old Apr 21, 2005 | 03:39 PM
Wadebryant's Avatar
What replacement temp switch did you purchase and plan to install? Kinda lost me there... The 180 themostat will open sooner than the OEM unit but, alone wont keep your motor running cooler if your fan switch doesnt activate at a lower temp.
Old Apr 21, 2005 | 05:22 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
well im going to go with the 200 temp switch, and i already have a 180 thermostat and i think that they will work well together
Old Apr 22, 2005 | 06:42 AM
Wadebryant's Avatar
Sounds good. Happy motoring!
Old Apr 26, 2005 | 04:15 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
here
Old Apr 26, 2005 | 03:23 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
thanks alot that really does help
Old Apr 30, 2005 | 10:11 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I nominate "jconrad" as most helpful new member in the Cooling Forum".
Old May 8, 2005 | 09:02 PM
rob37nc's Avatar
Car: 1992 camaro rs
Engine: 305 tbi
Hey fellas, I just put the fan switch from madvet, that one of you sugested. With a 180 degre thermostat. It`s a stock 92 305 tbi, auto. It seems to me it must be kicking my fan on once the 180 thermostat opens up. Like 150 degres on my instrument panel. Way too soon for me. Any suggestions ????????? Idid put the switch I bought fom autozone back in. it kicks the fan on around 220 or so.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
