Factory Block Heater - High RPM
Old Mar 24, 2005 | 08:28 AM
SNET Telly's Avatar
Car: 92 1LE B4C
Has anyone else had a problem with the O-ring on the factory block heater blowing out at high RPM's. My just did and I thinking just replacing it with a freeze plug. Its there any aftermarket block heaters that can take its place that somehow don't depend on just a little O-ring.
Old Apr 12, 2005 | 04:36 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Whats a Block Heater on a Camaro. I thought them only came on diesels.
Old Apr 12, 2005 | 10:20 PM
SNET Telly's Avatar
Car: 92 1LE B4C
Go's in place of one of the freeze plugs, with a power cord that you can plug a extision cord into. It heats up you coolant when your car is setting out on those realy cold nights, so it dosen't freeze or take forever to heat up. My came from Dever, but I think all Police package cars got them (B4C)
Old Apr 12, 2005 | 10:49 PM
Mojave's Avatar
My B4C doesnt have a block heater. But it was a Texas Highway Patrol car, and it doesnt really get that cold down here.
Old Apr 12, 2005 | 11:12 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I didn't think any third gens came with block heaters, maybe a dealer added option. Sounds like a good question for the history board.
Old Apr 12, 2005 | 11:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it did come with a block heater, I wouldn't think it would be sealed with an O-ring.
Old Apr 13, 2005 | 05:03 PM
SNET Telly's Avatar
Car: 92 1LE B4C
I found this Wep page stating a 92 B4C with a block heater. But I've got a feeling it might be my car. I Just bought it Oct 03 and it has a lot of work done on the front end. I'll see if I can find any others.
http://www.darnell.org/camaro/
Old Apr 13, 2005 | 05:16 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
There was a block heater on the 93 cop 350 TBI engine that I had put into my car.
I missed third and the ensuing over-rev blew the heater unit out a bit, and the o-ring type seal went popped out as well. TFG for the MSD 6Al w/rev limiter.
I seem to recall the seal being o-ring type material, but having a rectangular cross-section (though it was a bit battered by the time I saw it). The heater is only secured in the block with something that operates along the lines of a drywall toggle. The rubber ring makes the actual seal.
Anywho, I replaced it with a standard brass freeze plug- no big deal since it was on the drivers side near rear of the block.
S-D
Old Apr 13, 2005 | 09:51 PM
SNET Telly's Avatar
Car: 92 1LE B4C
sounds just like mine and in the same place. I just replaced it with a freeze plug still seing a antifreeze hanging around the bottom of the heater. Plus I was scared to realy step on and get stranded again with that thing in their with just a little o-ring sealing it.
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
BBSDesigns
Aug 11, 2015 07:39 PM
