Install a ballcock on the new Griffin Rad???
Old Mar 28, 2005 | 10:02 AM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
My new 31"x19" Griffin didn't have a ballcock installed....so is everyone just removing the lower radiator hose to drain and flush the coolant when it's needed??? Is it worth it to take the time and install a ballcock???
- Joel
Old May 7, 2005 | 04:06 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
ttt
Old May 28, 2005 | 07:21 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
IMO...no.
Most rad drains I've had end up spraying on top of a sway bar, or trickling down to the lower part of the fan shroud -but that depends on what position/angle the drain is installed I'd think..
Just use a clean big pan, and carefully inch the hose off the water pump end -and control the flow yourself - faster that way too.
Old May 30, 2005 | 07:02 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
...or buy a radiator hose drain that splices into the lower hose.
I'm using the straight Moroso unit with my Griffin 31x19".
Here are a few that Summit stocks.
http://store.summitracing.com/defaul...0&autoview=sku
-Rich-
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
