Quick question, Condenser...Thanks
Old Apr 9, 2005 | 06:08 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I am removing the AC and Condenser, and one tube on the condenser goes to that black cannister thing next to my battery...I provided a pic of it...can i just remove the tube from the cannister?....can i also remove the cannister and the entire tube length that leads up to the air box near the firwall? Thanks.
http://photobucket.com/albums/y42/1988camaro/?
Old Apr 9, 2005 | 10:44 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Link doesn't work, it says you have to sign in. I'm sure I can help, but I just want to make sure I understand what your referring to.
Old Apr 10, 2005 | 08:42 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
thats the evaporator/dry if my memory serves..... if you are removing the a/c nad have it discharged alreay yea... take everything from the a/c out
Old Apr 11, 2005 | 11:47 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
if it's the canister then its the reciever dryer, the evaporator is located in the firewall area closest to the vents inside the car. aside from discharging the a/c system you can just yank off all that crap no problem, but you will need either a shorter belt or a a/c delete pulley to run your serpentine. i think. well thats atleast how it was on my 92RS. and make sure you don't get the pag oil all over yourself when you take off the compressor like i did
Old Apr 12, 2005 | 03:15 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
ok... well as long as we are in agreement on the fact that it can come out
if you are removing the a/c tho, you want to pickup a heater only box
Old Apr 13, 2005 | 12:55 PM
Car: 1988 SC Camaro
Engine: 305 TBI
heater box?
why do you say i need a heater only box? Can't i just remove the AC and condenser and all the tubes and then just plug or cap off this hose/hole (see pic) Also, there is another hose that i capped off that connected to the black cannister thing...
http://http://photobucket.com/albums...ictureSEND.jpg[/IMG]
Old Apr 13, 2005 | 02:26 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i dont see why not... but the heater only box is smaller and looks cleaner in the engine bay.. i shoulda said you might want to get a heater only box
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
