Heavy duty coolant fan switch/sensor
Old Apr 13, 2005 | 01:02 PM
Todd 92 Z's Avatar
My heavy duty coolant fan switch (the one on passenger side between the rear plugs) is bad and keeps my second fan running all the time.
I'm going to replace it, how much coolant will I lose when I take it out?
I've never replaced one of these and I don't want to be under there in that tight spot and have coolant spilling everywhere.
Thanks in advance!
Old Apr 13, 2005 | 01:15 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
When I replaced mine I don't remember how much coolant came out, but I don't think it was that much. I added some to the overflow but not much.
Old Apr 13, 2005 | 01:43 PM
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
Check your wiring diagram first before you declare the switch bad,, most Birds have the on signal fron that switch(a ground) hooked to the primary fan on circuit so if both fans aren't running constantly, problem may be elseware like secondary fan relay..
Old Apr 13, 2005 | 01:56 PM
Todd 92 Z's Avatar
Yeah it's not the relay I checked that with a known good one and same thing.
It was only the secondary fan always on not the primary.
I got under there and pulled the harness off the switch and problem solved fan not always running.
I actually have a manual switch hooked up to the secondary relay from years ago when I had an overheating problem so I can still turn the fan on and off manually.
Do I really need to replace this switch or would it be ok to just leave it unplugged?
I've been reading this is just a "safety net" in case the ecm doesn't do it's job turning on the fans.
The dealer wants $25 for it and Nappa wants $19,I don't wanna waste the money if I really don't need it.
Old Apr 13, 2005 | 03:27 PM
Car: 88formulatp1
Engine: 5.0
Transmission: 5
Well, there's only one time that you'll really, really wish that it worked! Someone on this board will sell you a known good used one for less, lotso them layin' around....
Old Apr 13, 2005 | 03:50 PM
91Z28-350's Avatar
Quite a bit. Drain the coolant first, then pull the switch with a catch pan and let it drain out.
Old Apr 13, 2005 | 08:38 PM
Todd 92 Z's Avatar
Thanks for the replies guys!
I went to Nappa and got a new one, problem solved!
I lost quite a bit of coolant but I had a big catch pan so no problem.
I figured it was on the car for a reason so might as well replace it.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
sheachopper
Jul 31, 2019 11:27 AM
MrPackstin
Oct 25, 2017 08:09 PM
ULTM8Z
Oct 2, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
