Wanting to fix a hack job
Old Apr 12, 2005 | 12:02 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I just bought a '91 Z28 with the dual rad fans, but a previous owner bypassed the ECM and fan switch, so they're hooked up to a toggle switch. Well, I really would like to return the duty to the stock configuration or if I could, hook them both up to the ECM.
a) Why did GM make them so one is turned on by the ECM and the other by the pass side head fan switch? Why not just let the ECM turn them both on?
b) Are there any drawbacks to letting the ECM control both?
This might be more for the DIY-PROM section, but is it possible to have have both fans controlled (at different temps), or is our wiring harness not set up for it? I see in the AUJP.bin with the $8d that there is a provision for separate turnon temps for each fan.
Closest thing I found was this.
https://www.thirdgen.org/techbb2/sho...&highlight=fan
Old Apr 12, 2005 | 12:08 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Well, I think I finally found it. Looks like it's been explored before. https://www.thirdgen.org/techbb2/sho...&highlight=fan
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
jackhammer
Aug 15, 2015 10:04 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Amillionoh7
Aug 7, 2015 01:24 PM
