AC Delete question
Old Apr 18, 2005 | 02:11 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
AC Delete question
Hope this is the right board and not something that's been covered over and over.... so here's the deal, I've done the AC delete process, and today my non AC heater box came in the mail, is it a simple bolt-on/plug n play deal, or is there more to it?
Old Apr 18, 2005 | 11:37 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
should directly replace your old heater/evap box. only, this one won't have room for an evap core.
Old Apr 19, 2005 | 02:05 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
sounds good, there's no wiring difference tho, other than the plugs that came off the old AC hardware won't get plugged back in anywhere?
Old Apr 19, 2005 | 08:40 AM
Car: 1982 Trans Am
Engine: 383 chevy
nope. if you wanted, you could even cut them off. it won't hurt anything. I would recommend you keep them, though, unless this is a race car, or there is no way you could sell it.
Old Apr 19, 2005 | 06:18 PM
z28colt's Avatar
Car: '92 RS
Engine: Working on LT1 Install
Transmission: Working on T56 Install
Where did you pick up your a/c delete heater box? Anyone know of a good place to order one off the Internet?
Old Apr 19, 2005 | 09:44 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
ebay
Old Apr 24, 2005 | 12:18 PM
BOTTLEDZ28's Avatar
Transmission: A4
it is not a 100% bolt in install. If you want to keep the wiring the same then yopu will have to reuse your sensor that was on the A/C box and you will havew to reuse your blower motor. The A/C blower motor has 4 speeds and the non A/C ones only have 3. If you want the keep the 4 speed one then some modifications will need to be made to get it to work. The blower fan(hamster wheel) on the A/C motor is deeper then the non A/C one and it will rub against the firewall when you turn your heat one. You must move the motor outward about 1/2" . There is a tech article on it on this site somewhere.
Old Apr 24, 2005 | 11:29 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
but if i use the non-ac blower motor, will it still work, but only at 3 speeds? if that's the case, then that's fine with me.
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 22, 2015 07:49 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
