91 1le fan switch control problem
Old Apr 29, 2005 | 06:33 PM
antmonty's Avatar
Car: 91 1le
I have search the forum and not found this issue yet. I have a 91 1le 305 5speed, single fan, aftermarket a/c installed. There is no wire on the fan switch on the passenger side head. The fan does come on at about 240deg.
Is that the way the fan wiring is supposed to be hooked up?
or should have it been hooked to the switch on the passenger head originally?
Thanks for the help.
Old May 9, 2005 | 01:43 PM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Transmission: WC T-5
Man, I got the same question. I have a 1991 1LE, I also have the switch between #6-#8 cylinders with no wire going to it. I looked everywhere, and I cannot find the wire or harness that goes to it. I do not know how hot mine will get until the fan kicks on. It got up past 220 on the gauge and I started to worry, so I headed home. I tried to get a fan switch that comes on at a lower setting, but I guess that does no good if there is no wire on it! Maybe it controled by the ECM. Hopefuly an updated prom could make it come on quicker. Thanks, now I know I am not crazy for not finding a wire!
By the way, What A/C system are you running? I am getting a Vintage aire unit installed this week. Any tips? Thanks again!
Old May 11, 2005 | 12:44 PM
1quikformula's Avatar
Car: 1991 Pontiac Formula
Engine: 350 C.I
Transmission: 700R-4
You may want to jack the car up and check near the starter it could have just came loose and just hanging there. I also believe the ECM is programed to turn on the fan if the engine gets too hot. quinda like a fail safe system where if the fan switch failed the ECM would eventually turn it on, but don't quote me on this.
Old May 11, 2005 | 03:17 PM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Man, I looked all over for that wire. I will look again near the starter, thanks.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
