Flex-a-Lite
Old May 1, 2005 | 10:08 AM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
Flex-a-Lite
Does anyone have a Flex-A-Lite fan and if so do you notice a difference in performance or anything? I'm thinking of getting one but if there's no noticeable difference I'll stick with the belt driven stock fan. Also when installing one of these electric fans, what happens to the remaining belts and the water pump pulley? Do they stay on or is there some sort of replacement assembly? Thanks
Old May 1, 2005 | 12:43 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I'd go with 2 flex-a-lites. I don't think one will do the job. I could be wrong.
Old May 1, 2005 | 04:40 PM
Have you or anyone else done this and can offer some insight to the other questions i had?
Old May 1, 2005 | 07:09 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
The water pump must stay on the car.Cooling not too effective without it. All you have to do is remove the fan from the pulley. Everything else stays as is. It should give you more horsepower, but don't expect it to snap your head back. (about 10 HP)
Old May 1, 2005 | 08:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Over a properly working clutch fan, probably not as much as 10 HP even.
Old May 1, 2005 | 08:27 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
I don't think those fans had clutches, but I could be wrong.
Old May 1, 2005 | 09:19 PM
Yeah it's got a fan clutch. And I wasn't talking about removing the water pump itself i'm wonder what holds the water pump pulley ON since the fan and clutch are mounted to the pulley viw studs and nuts.
Old May 2, 2005 | 12:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The water pump pulley is mounted on the same studs as the fan hub.
Old May 2, 2005 | 01:53 PM
just with the original nuts?
Old May 2, 2005 | 02:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sure, why not?
Old May 2, 2005 | 02:52 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
I had to add a washer to each stud for the nuts to sit right
Old May 2, 2005 | 04:16 PM
good to know... i think everyone else is a little confused as to what i was trying to get at here
Old May 26, 2005 | 12:46 PM
Twelvz's Avatar
Car: 89IROC
Engine: Forged 355 AFR195
Transmission: 700R4 Vigilante Converter
Axle/Gears: Strange 12 bolt 3.73
http://www.flex-a-lite.com/auto/html..._radiator.html
I'm looking at getting one of these
roughskinjrz
Jul 10, 2007 10:41 PM
ZEEYAA
Jan 27, 2007 09:10 PM
