Temp gauge has a mind of it own. HELP
Old May 8, 2005 | 10:43 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
Ok here it is my temp gauge stoped working it now reades 0 but some days it goes crazy. I will go from 0 to 260 back and forth and do that for a long time then back to 0 does any one now how to fix this a need a temp gauge. the engine is a 87 formula with a 350 TPI
Old May 8, 2005 | 11:50 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
that sounds like you need a new temp sender
Old May 9, 2005 | 06:28 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
or has the wire come off the sender and the terminal bouncing around on something? if it's off, it'll read "0". if it hits a ground somewhere, it'll max out "260". check your wire. if that ain't it, change your senser.
KAM
Old May 20, 2005 | 02:37 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Is the temp sender the one on the driver side beneath the exhaust manifold? I have the same exact problem.
Old May 22, 2005 | 12:54 PM
Car: 91 formula
does anyone have a picture of what the temp sender looks like. is it attached to a wire?
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
