Where did my fan switch harness go?!
Old May 9, 2005 | 07:55 AM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Transmission: WC T-5
I thought I was having the problem most people were having of the fan switch not kicking in soon enough, so I bought a fan switch from Mid America, and when I got my car on jackstands, I got a surprise. I have the fan switch, between #6 & #8 cylinders, but there is no harness connected to it, or anywhere near it! Where would this wiring harness come from? I need to some how trace back so I can find where it went.
I have only one cooling fan. Is this switch for the double fan setup? Do I need a different switch and harness adapter for the primary switch?
Another question- what is the switch betwen the #1 & #3 cylinders with a green wire and a blade type connector?
Here is a pic of the switch between #6 & #8:
Old May 9, 2005 | 03:42 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Drivers side (1 & 3) is a sender
Old May 10, 2005 | 09:15 PM
allisonguy's Avatar
Car: 1984 camaro Z 28
Engine: 305 H.O. L-69
Transmission: 5-speed
On my 84Z the sending unit between 1&3 is for the analog gauge, the fan switch is between 6&8 and the wire to the switch is a green wire in a harness on right side of the intake that also contains the wire for the electric choke and the alternator. Stock plug is a male pin type that pushes on.
Old May 11, 2005 | 01:48 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The wire for that fan switch gets fed down between the a/c compressor bracket and the cylinder head (in the big loom).. My approach would be to disconnect the starter wiring, knock sensor and bring the serpentine bracket on the passenger side off so you can bring that portion of the wiring harness up... Then see if you can find the (green?) wire that goes to the fan switch...
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
Chuck84TA
Aug 27, 2015 11:14 AM
TA8487
Aug 16, 2015 12:21 PM
