which electric fan should i use with the iron duke?
Old May 24, 2005 | 03:48 AM
mars22's Avatar
Car: 83 firebird s/e w/ttops and a/c
Engine: 2.5 iron duke/ tech IV
Transmission: 5 speed
i want to switch to an efan but i dont know which one, i live in florida so i need alot of cooling ,the cooler the better.
Old May 24, 2005 | 04:00 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Get dual 12s or a nice 16" should work fine. I run 1x10" and 1x16" (about 24-2600CFM) on my car in the Mojave Desert
Old May 24, 2005 | 10:04 PM
mars22's Avatar
what temp does it run at? and how much were they?
Old May 25, 2005 | 12:09 AM
Car: 85 Trans Am
I have a Northern 31x19 2x1 so take with a little variance
This weekend we had 98F, i went out for 30 minutes (was prewarmed also) never went above 210, fans are set at about 200 or so. This was all stop, turn go, stop...
They are both from Kragens, about 110 altogether.
Old May 25, 2005 | 01:31 AM
mars22's Avatar
cool,pun intended
Old May 25, 2005 | 04:29 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
since your trying to go for peak efficiency why would you want the fan to run on at 200*?
you should be looking at more like the 210 to 220 area for your gas mileage mars
gta892000
Aug 11, 2019 11:16 AM
Grant2k
Apr 4, 2016 08:21 AM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
