I cross threaded the coolant line!
Old May 29, 2005 | 05:25 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I cross threaded the bottom transmission line on the rad.I knew it was gonna happen. I went real slow and thought it was good but still managed to do it. I was thinking that instead of removing the raqd again, and somehow fixing it, could I just install a tranny cooler and bypass the one in the rad? If so can I just leave the rad ones open?
Old May 30, 2005 | 02:30 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
"If so can I just leave the rad ones open",... yes.
but you don't want the biggest trans cooler you can buy, you want the biggest trans cool you can properly mount in front of the A/C condenser,... the bigger the better. you may also want to get a trans temp gage & install it as where you are at, the trans may not warm up enough in the winter,.. too cold isn't good on the tranny either.
Old May 30, 2005 | 02:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Chances are you've stripped the threads in the nut, not in the cooler.
Old May 30, 2005 | 06:18 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Thats what I was hoping but no, brass filings where all over the place. I got a 4"x11" 3/4" thick cooler, should this be sufficient?
Old Sep 15, 2005 | 05:20 PM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
What would be the fix for an over-cooled transmission? Some type of thermostat on the trans cooler?
I'm going to be putting one on my bird, and of course I don't want to fry the transmission by getting it too cool either.
Old Sep 15, 2005 | 05:54 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My friend's running a $40 cooler from Summit Racing in his bird. Too large of a cooler is definitely a bad thing though.
Old Sep 15, 2005 | 06:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could use a thermostat (Perma-cool makes one IIRC), or you could install the auxiliary cooler inline before the rad, so that the factory cooler warms the fluid up to normal operating temperature.
Street Lethal
Apr 30, 2019 12:14 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
