More Trouble but Fan Switch Works
Old May 30, 2005 | 06:38 PM
DF'sCamaro's Avatar
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
So I got the air out of the cooling system and the Fan Switch works excellent comes on at 200F off at 175F. Only thing is since I replaced my started cause I broke one of the studs(look at earlier post) my car now makes a weird noise like gravel is in the starter but it was not the starter i had it tested and it was fine. While at OReillys a guy said it could be my clutch springs going out and its just a coincidence that it happen while installing the new starter. What do you guys think it coming from around the starter but the starter tested fine it in that area and it comes and goes while driving. Like I said it sounds like loose graven in can swirling around that the best I can describe it. Yea I did know where to post this cause I dont know what the hell the problem is.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
