overheating
Old Jun 7, 2005 | 09:08 PM
badass91camaro's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
overheating
i had to replace my head gaskets, while doing so I broke the cooling switch sensor, and the boot that connected it. I bought a new switch, and now the fan isnt kicking on when the car gets hot. The fan will turn on though when i turn on the a/c. Checked all the fuses, replaced the fan motor, and thermostat. I am running out of options. Any help will be greatly appriciated.
Thanks.
Old Jun 7, 2005 | 09:29 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
If you are talking of the fan switch it grounds the circut when the temperature reaches a preset point. Perhaps you missed a connection somewhere?
Old Jun 7, 2005 | 09:33 PM
CONV Z28's Avatar
Car: 91 Z28 conv
Engine: Scoggin-Dickey Chevrolet TPI 350,MSD,Flowmaster, BBK,edlbrock,Fastchip,24lb svo injectors
Transmission: 700r4 Bowtie stage 3 / 2400 RPM stall converter
Sounds like a bad fan relay... Its location is next to your matser cylinder looks like a small black box. there is more than one relay in that area, I believe it's on the driver side.
Old Jun 8, 2005 | 06:08 AM
JoshDT91's Avatar
Engine: 2.8L V6
If it is the relay isn't that located on the passenger's side of the radiator? I see two locations for it, the one CONVZ28 mentioned and the one I mentioned maybe someone can straighten it out.
Old Jun 8, 2005 | 06:23 PM
Car: 91 Camaro RS
Engine: 305 TBI
thank you for the help gonna go check the fan relay next to the clutch master cylinder 1st since its the oldest. thanks again!!
Old Jun 9, 2005 | 05:59 AM
JoshDT91's Avatar
Engine: 2.8L V6
I don't know what I was thinking but CONV Z28 is right.
Old Jun 10, 2005 | 03:17 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
cooling fan switch
mine was doing the same thing until i got a ac delco switch instead of the wells brand .when the it got to 200 the fan kicked on
Old Jun 10, 2005 | 06:48 PM
drumsk's Avatar
cooling fan switch
The my auto parts dealer gave me was a standard ts 147
I beleive. but it turns on at 220 + this may be a secondary switch for a tpi set up. Can some one tell me what the propper part # is for the correct fan switch is. Mine use to kick on a 210 about and shut off at 190 or 180 it doesn't even come on now
I have to leave the ac on all the time.......
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
